I have a philips KTY84/130 temperature and I am trying to calibrate measurement for Max
what kind of measurement should I use? I have tried to use the resistor
acquisition type with a custom scale comming from the attached file and
using an external power supply 5v trough a resistor of 1kohm but the
measured value with this setup is giving me almost 69 degrees C and the
sensor is only measuring ambiant temperature.
I have also tried to use Temperature Vex measurement with the same
setup, and the A,B,C values comming from the attached datasheet file,
it still gving me 60 degrees C.
I attached my MAX configuration file.
Thanks for help
Olivier
