LabWindows/CVI
How to change text on tab control
This is a very simple question, but I cannot find any clear direction on how to do this!
How do I change the text on the tab of a tab control?
(870 Views)
Hi Barney,
If you double-click on the tab control, a dialog will appear and you can edit it directly as shown in the image below.
If you want to do it programmatically, you can refer to the code in the link below on how to edit tab control.
Use InsertTabPage to add tab pages to the tab control.
InsertTabPage (panelHandle, PANEL_TAB, 1, "Tab 1");
https://www.ni.com/docs/en-US/bundle/labwindows-cvi/page/cvi/uiref/cviprogramming_with_tab_controls....
(843 Views)
