LabWindows/CVI
How to change the language of NI MAX (from German to English)
Hello All,
I have recently installed an NI DAQmx package for workig with Labwindows. By mistake it was installed in German.
Now I am unable to find how to change the display language to English.
Do I have to reinstall the software or can it be done via some options?
Raunak
(7,713 Views)
Accepted by topic author erraunakgupta
I don't know for new releases, but in the past I was able to change the language changing the OS regional settings (see here).
If you like it, feel free to give your kudo to this idea.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(7,700 Views)
Hi Raunak,
Is the version of MAX the latest, if not then try to upgrade your drivers, as it will upgrade your MAX version as well, and maybe you will get the correct language selection then.
Cheers,
Rao
(7,687 Views)
Thanks a lot, it actually worked. 🙂
(7,678 Views)
