LabWindows/CVI
How to change the output executable file name(a.prj:(output)--->b.exe)
LabWindows / CVI: how to change the output executable file name
            For example, I have an A project a.prj, I do not want to compile the output file is a.exe, but b.exe.
I will try to save as a.prj b.prj, a.cws save as b.cws
eg:a.prj  ---->(output)--->b.exe
(4,862 Views)
Accepted by topic author GD.Huang
You can go to Build >> Target Settings menu item, select Release (or Release 64) in the Configuration filed and set the name of the executable to create in Application FIle field, withouyt need to change the prj or cws filename.
See the complete description of available options here.
(4,854 Views)
Thank you for your help, that's my first time to learn CVI,found that it's so excellent!
(4,837 Views)
