LabWindows/CVI
How to change the size of the declared array
     I need to change the size of the array when the program is on the fly because I need to change the array size whenever the user change the select area and then put this array into an array list.  Thus, I don't know how to achieve this goal in the C language. Please give me some suggestions. Thank you very much!!
Mitchell
(4,004 Views)
If you want the size of an array to vary during the execution of the program it must be dynamically allocated using malloc() or calloc(). I put together a small example of this in which when the array is resized, the contents are persisted as possible. This example elides error handling (such as an allocation failing) etc. but it should get you started.
I should mention that a potentially easier solution may be to use Handles instead of managing the array yourself; doing this is not a portable solution but it is a nice alternative that would do most of this management for you.
#define MIN(a, b) ((a) < (b) ? (a) : (b))
// *pArray can be NULL, oldSize or newSize can be zero
// newSize == zero will free up the array
void ChangeArraySize(int **pArray, int oldSize, int newSize)
    int *newArray;
    // allocate the space for the new array unless the size is <= 0
    if (newSize > 0)
        newArray = malloc(newSize * sizeof(int));
    else
        newArray = NULL;
    // if an array already exists
    if (*pArray)
        // copy elements if necessary
        if (oldSize > 0 && newSize > 0)
            memcpy (*pArray, newArray, MIN(oldSize, newSize) * sizeof(int));
        // free up the old array
        free(*pArray);
    // drop the new array in
    *pArray = newArray;
int main(void)
    int *array = NULL, arraySize = 0, i ;
    ChangeArraySize(&array, arraySize, 100); // initial array allocation
    arraySize = 100; // keep track of the current size
    for (i = 0; i < arraySize; ++i)
        array[i] = i;
    ChangeArraySize(&array, arraySize, 50); // elements 0-49 are maintained
    arraySize = 50;
    for (i = 0; i < arraySize; ++i) // prints 0..49
        printf("%d\n", i);
    ChangeArraySize(&array, arraySize, 0); // free up
    return 0;
Message Edited by Alex D on 07-02-2005 11:06 PM
(3,989 Views)
Is there an advantage of this method over using realloc()?
(3,966 Views)
The way I wrote the example, not really; that's basically what I implemented. The main reason I did it the long way was in the original post 48105 said, "I need to change the array size whenever the user change the select area and then put this array into an array list." The "put this array into an array list" led me to think that maybe he would want a slightly customized version that would leave the old array around so I tried to provide something that could be made a bit more flexible.
You're entirely correct; realloc would do essentially what I provided.
(3,951 Views)
The number of stars you received probably indicates you were correct in your assumption 🙂
Thanks for the explanation.
Kind regards,
Erwin Timmerman
(3,932 Views)
Another word on realloc.  If you are putting your pointer into a list and using realloc, then there isn't going to be a problem, but if you are just storing the address of the pointer in a list then you could run into problems.  Because when you allocate memory it has to be contiguous, it is possible (though in practice I don't think it happens too often) that when you realloc a larger amount of memory than you previously had, it could change the address of the pointer.  If you have a list of pointers this isn't going to be a problem, but if you just have the memory address stored then suddenly you have an address that points to the wrong location.
(3,923 Views)
