LabWindows/CVI
How to check if receiving data from serial port
Basically i have a programed so that i received data from the serial port using InstallComCallback(). In my interface i hv an led for incoming data...which lits when i start receiving data and stops when i stop reading data from comport......but say for example someone pulls the serial cable out or something....i would like the led to go off........i am hving trouble with that.... i tried using GetComStat() but no luck, maybe i am not using it correctly....
hope someone can help me out.
k1_ke
(4,540 Views)
RS232Error=OpenComConfig();
RS232Error- find the corrcet error code for port not open / port errors..
..may be it helps
(4,530 Views)
Try: GetComLineStatus()
Function help says:
Hardware-specific information about the status of the selected port.
The status word is comprised of individual bits, each with a different meaning. This parameter is filled in with a combination of the following values:
Name Value Description
kRS_CTS_ON 0x10 The CTS (clear-to-send) signal is on.
kRS_DSR_ON 0x20 The DSR (data-set-ready) signal is on.
kRS_RING_ON 0x40 The ring indicator signal is on.
kRS_RLSD_ON 0x80 The RLSD (receive-line-signal-detect) signal is on.
Check if you see anything change on the DSR line when you disconnect the cable. If not that line is not in the cable.
(4,515 Views)
Hi guys,
Thanks for the replies. Well i had looked at those options but didnt use them because just incase the serial cable been used didnt have all the handshaking capabities and yeah i had also forgotton to mention that in my previous post.
But overall thanks for the help! i was able to solve my problem though.....i just made my own routine with my messege pops
k1_ke
(4,505 Views)
