LabWindows/CVI
How to close a CVI Application from VC++ Aplication
I am trying to close a CVI application from a VC++ 6.0 application, But I can.
I tried with DestroyWindows(); PostMessage(hwnd, WM_CLOSE, 0,0) and Still I can not doit.
Can somebody help me.
(3,848 Views)
You shuld use RegisterWinMsgCallback in CVI to catch Windows standard
messages.
Marco Turra
Soft. Department
HI-TEC S.r.l.
Via Agrigento 9
20148 - MILAN
ITALY
Tel. +39.02.39262464
Fax. +39.02.39260434
Web Site: http://www.hi-tec.it
E-mail : marco.turra@hi-tec.it
"Wilbert" wrote in message
news:50650000000800000043E70000-1079395200000@exchange.ni.com...
> But I can.
> Thanks
(3,848 Views)
you may want to give the main callback a try. CVI can install a callback for external messages that are sent to the application. You need to call InstallMainCallback() to set this callback up and you should get a EVENT_END_TASK when VC++ send the terminate message.
There is more information on this in the following document: How Do I Programmatically Detect If a User Pressed 'Ctrl-Alt-Delete' in LabWindows/CVI?
Let me know if you have any further questions.
Juan Carlos
N.I.
(3,848 Views)
Do you have a Sample in National Instrument Site ?
(3,848 Views)
I could not find any examples on our website; however I created a small example for you. The main caveat on doing this is the window the name that you use for FindWindow().
If you get a handle of the panel, the panel closes but the application is still active. To close the application and get the EVENT_END_TASK you must get a handle to the CVI application. So you must pass to FindWindow the name of the project.
There are 2 CVI projects here, the project MainCallback demonstrates how to use the main callback and quits the application by posting a close message. The second project just posts the message to close the application.
Please take a look at these projects and let me know if you have any further questions.
Regar
ds,
Juan Carlos
N.I.
(3,848 Views)
Juan Carlos.
Thanks for your help, Let me check te files and I tell you if its work.
(3,848 Views)
Any time, I'll keep an eye on this posting.
Good luck with your project.
J.C.
(3,848 Views)
