LabWindows/CVI
How to communicate between application
I'm not sure I know what you mean by your reference to "Call Library Node"? Or your reference to VIs (this is the CVI board, where people expect to write C code...). The entire amount of C code to write, in order to satisfy the original requirement (ie one process to start/stop another on the same computer), was presented in my example. Agreed this limits the implementation to the Windows platform but I was not attempting to produce a solution to a problem that did not exist. I could post my alternative solutions for networked and/or dll based data transfer, but that was not the original problem posed.
JR
Message 11 of 15
(2,281 Views)
You are of course right! I missed that this was for CVI since this thread was referenced from a LabVIEW related discussion.
Sorry for that.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 12 of 15
(2,281 Views)
You're not the only one to miss things - I've only just noticed that the original post is actually 1 year old! Smiley Very Happy
JR
Message 13 of 15
(2,271 Views)
Hi JR,
nevertheless that the question is very old I am still watching it. And I am always thankfull for ideas to improve my projects.
Your idea is very interesting and I think I will try it also.
Meanwhile the project is running, but it is interesting to see other possibilities also.
greetings
Oliver
Message 14 of 15
(2,251 Views)
An alternative option would be to use Dynamic Data Exchange. One program would act as the server and the other as a client, you can then pass commands between the two. It works by passing data from the one to the other in memory. The client would call a function and pass a data payload to send, the server would recieve a callback with the data and then act on it.
Might be a bit overkill for this application however its a usefull skill to learn.
RadioAct
Message 15 of 15
(2,240 Views)
