LabWindows/CVI
How to control master volume in window cvi
(3,495 Views)
You will need to use the Windows multimedia SDK functions for this. You will need to install the windows SDK functions support in CVI ( if you have not already done that ) by restarting the CVI installer, selecting modify and enabling the SDK option. Refer to the Microsoft Developer Network here for more information on the functions themselves.
Bilal Durrani
NI
Bilal Durrani
NI
(3,494 Views)
    Can you (or someone else) post a little example of how to control de master volume and mute/unmute de volume?
(3,343 Views)
As Bilal mentioned in his previous post you will need to use the Windows multimedia SDK functions for this.  In particular I would take a look at the waveOutSetVolume function. I have posted a link that gives a little more information on this function. There are some examples, but they are visual basic rather than ANSI C. However it should help to give a general idea of how to use the function.  Hope this helps!
Link to help on waveOutSetVolume
Message Edited by Patrick P. on 02-05-2007 07:22 PM
Pat P.
Software Engineer
(3,309 Views)
