LabWindows/CVI
How to control parallel port under Japanese Windows2K by using CVI6.0?
Using CVI 6.0, I wrote some program to control parallel port. Under the English Windows OS it works fine. But under JaPanese Windows OS it did not work. I call NI support team they give me some example. I try the example, it behaved same way as my program. The attach files is the example files. Please help and thank you all.
(3,031 Views)
It is ok now. With NI support team, we solve this problem.
Thank you all.
(3,031 Views)
But what was the solution? 🙂
(3,031 Views)
