LabWindows/CVI
How to convert safearray to lpsafearray?
Hello! Im working with Version 7.1.0.
Does anybody how convert the datatype (pointer of) SAFEARRAY in LPSAFEARRAY???
My ActiveX-Control provides me an SAFEARRAY in the this function:
static SAFEARRAY *SampleArray; double * datapoints=NULL; ........
hResult = AXFifo4Prj__AXFifo4CaptureChBFifo (axfifo4Handle, &err, &numSamples, &SampleArray, &twosComplement, &vBool ); //&*SampleArray
CA_SafeArrayTo1DArray (&*SampleArray, CAVT_DOUBLE,&datapoints,&numSamples);
needs an LPSAFARRAY, so the pointer is already included.
The CA_SafeArrayTo1DArray code line produces this error message:
49, 49 Type error in argument 1 to `CA_SafeArrayTo1DArray'; found 'pointer to SAFEARRAY' expected 'pointer to LPSAFEARRAY'.
Thanks for every help!
(5,075 Views)
Try this
static LPSAFEARRAY SampleArray;
hResult = AXFifo4Prj__AXFifo4CaptureChBFifo (axfifo4Handle, &err, &numSamples, SampleArray, &twosComplement, &vBool ); //&*SampleArray
CA_SafeArrayTo1DArray (&SampleArray, CAVT_DOUBLE,&datapoints,&numSamples);
Note : The above safe array function has been superceded by CA_SafeArrayTo1DArrayEx(). And remember to use CA_FreeMemory() to free the C array that is returned.
Hope this helps
Bilal Durrani
NI
(5,061 Views)
How about if we need to do the reverse i.e. convert from lpsafearray to safearray?
Does similar type casting work?
thanks.
(5,034 Views)
an lpsafearray is just a pointer to a safearray. you can dereference the lpsafearray to get the safearray.
Just make sure you keep track of allocation and deallocation of the safearray.
Bilal Durrani
NI
(5,022 Views)
