LabWindows/CVI
How to copy a tree indicator values?
Hi folks!
In my application there is a tree indicator, with multuiple columns that I want to copy to another tree indicator. I want to copy entire tree, with all columns.
Is it possible to do it? How?
Thank you in advance!
(3,886 Views)
Check out the sample program samples\userint\treecopy.prj. It shows how to use the library function CopyTreeItem.
- jared
(3,873 Views)
Ok, I copy the tree and its first column, and the others columns? How can I copy them? Is it impossible to do it using a single command?
Thank you.
(3,868 Views)
You can call DuplicateCtrl to programmatically copy a control at run-time.
-Jeff
(3,824 Views)
