Hello Pascal,
The "Create Distribution Kit" in CVI does not register your driver in MAX. We have recently updated our own installers to write directly to the IVI Configuration Store XML file (so the software module and all other information will show up automatically in MAX), and also to install the driver files in the new IVI directory.
Since we already have the tools you need, we can create an installer for your IVI driver. If you would like to take an advantage of this free service, please send your driver (.c, .fp. .h, .sub, example.c, .ini) to instrument.driver@ni.com.
If you want to develop the installer creator yourself, you can find more information on the requirements in the following IVI specs:
IVI-3.1: Driver Architecture Specification (Chapter 6)
IVI-3.5: Configuration Server Specification
Both specs can be found on http://www.ivifoundation.org/ApprovedSpecs/Default.htm
Vesna Jadric
Instrument Drivers/IVI
