LabWindows/CVI
How to create a channel property in a tdms file
How do you create a channel property in a TDMS file. I've tried using the TDMS_SetChannelProperty as follows
for (i = 0; i < numChannels; i++)
     error = TDMS_SetChannelProperty (channels[i], :Color, TDMS_UInt32, colors[i]);
No error is generated but the data doesn't get written to the file?
(3,646 Views)
Hey,
I've been working with TDMS library lately.  Sorry, I haven't exactly tried that function though.  The help has this to say about parameter number 2:
property const char * The name of the channel property. You can specify a built-in property or a property created by TDMS_SetChannelProperty.
The following built-in properties are available:
Property Constant Data Type
Name                TDMS_CHANNEL_NAME                    String (char *)
Description      TDMS_CHANNEL_DESCRIPTION     String (char *)
Unit String        TDMS_CHANNEL_UNIT_STRING     String (char *)
I'm confused about yours.  What does ":Color" mean?  How does that compile?
(3,598 Views)
There is an error with the line
the actual line i send is as follows
Fmt(propertyName, "%s<%s", "Color\0");
channel is a TDMSChannelHandle
int color = 1234567;
error = TDMS_SetChannelProperty (channel, propertyName, TDMS_Int32, color);
(3,228 Views)
