LabWindows/CVI
How to create a .lib file for CVI?
I would like to create a static lib file for use in CVI.  I am trying to optimize some small functions by using inline assembly and CVI does not support inline assembly.  So I am compiling and linking using Visual studio.net.  When I run my CVI project, I receive a link error that the function name I am calling in the lib is an undefined symbol.  Does anyone have any experience with this?
(3,845 Views)
Sounds like you missed to include a .h file with function definitions, macros, prototypes and other common stuff associated with the lib file you created...
(3,830 Views)
No,  CVI found the prototype for the function, it doesn't like the lib file.
(3,817 Views)
Check the discussion on name mangling by C++ compilers here.  You probably need to add extern c references to the header before compiling your code with visual c++.
http://forums.ni.com/ni/board/message?board.id=180&message.id=11323&requireLogin=False
(3,810 Views)
