LabWindows/CVI
How to create an ActiveX Object and use it in LabView 8.5
i have a question concerning the ability from LabWindows/CVI.
Due to the fact, that a Table in LabView is not that flexible as a Table in LabWindows/CVI (It is not possible to customize a specified cell / column to be a e.g. ComboBox), i want to create such a table using LabWindows/CVI and the create a ActiveX object out of this Table to import it in my LabView application.
Does someone already have experience with this topic?
Thank you!
(3,281 Views)
Hi pahe,
Currently LabWindows/CVI doesn't offer the ability to create ActiveX controls. In this case, you might want to submit a product suggestion to our LabVIEW team to add that additional functionality to their table.  Also, sumbit a product suggetion to the CVI team as well for the ability to create ActiveX controls just so we have a record of the request.
Creating CVI DLLs is an option, but that will load up as a top-level window and not an embedded window in LabVIEW.
Best Regards,
Jonathan N.
(3,269 Views)
Thank You!
(3,260 Views)
