LabWindows/CVI
How to create an array using the niFgen library for the PXI-5411?
THE PROBLEM IS IN BEING ABLE TO FIND A FUNCTION FROM THE LIBRARY OF THE NIFGEN (VERSION 2.3.1) THAT HELPS ME TO CREATE OR TO EXTRACT AN ARRAY OF THE CHARACTERISTICS OF THE FUNCTION (I MEAN SIN, SQARE, TRIANGLE, ETC )THAT I SELECT IN MY PANEL AND BE ABLE GRAPH IN IT (IN A YPLOT FUNCTION), ALL THIS FOR THE PXI-5411.
THANKS!
(2,891 Views)
Hi Jorge Luis,
There's an example about creating an ploting arrays that might help you meanwhile I find something specific for NI-FGEN to tell you about.
The example is called arrayfile.prj, you can get to it in the example finder. Anyway, I'm posting it also.
I hope this helps.
Thanks for using NI forums.
Message Edited by Avarg on 02-14-2007 12:05 PM
Message Edited by Avarg on 02-14-2007 12:06 PM
Arturo Vargas
National Instruments de México
(2,856 Views)
