LabWindows/CVI
How to create and handle a text file in CVI
Is there any way to create and handle (like...open,write,read,truncate,close)  the .txt file in CVI?
(3,870 Views)
Sure. CVI is a regular C compiler and hence you can use all ANSI C functions. In addition you can use the File I/O functions from the utility library.
(3,868 Views)
