LabWindows/CVI
How to create distributed .exe of any CVI project
How to create distributed .exe of any CVI project that we can execute in any system which doesn't have CVI installed
(5,176 Views)
To have a CVI excutable running on a target system you must install the apropriate support libraries and modules on it: CVI integrates the ability to create proper installers that create the correct executing environment on the target machines. These functions are included in Build >> Distributions menu item: select "Manage distributions" and look into the detailed online help.
An overview on creating a distribution can be found in Using LabWindows/CVI >> Managing projects >>Building a project >> Distributing applications topic in the online help as well as in several forum threads and other documents on NI site: as an example, this one covers this topic for CVI 8.x
(5,168 Views)
And if you want to package it all up as a single file, I have had good success with the "WinZip Self-Extractor". It allows you to create a self-extracting exe from the zipped set of installation kit files, and when configured for software installation, will unzip first to a temp folder, run setup.exe and wait for it to finish, and then delete the installation kit files from the temp folder.
--Ian
(5,125 Views)
--Ian
(5,124 Views)
