LabWindows/CVI
How to create graphics on an excel sheet with ActiveX. Can't find examples.
Hello, I'm trying to create some classic histograms on an excel sheet using some ActiveX functions. But I can't find any example of applications to guide me. Can you help ?
(2,937 Views)
The following example program should give you a good start:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/97383d950b2b38fe862568940057d3b4?OpenDocument
For your application you will want to pay particular attention to the Excel_ChartChartWizard function call.
Also, if you want to write your ActiveX client from scratch in a new project, Use the ActiveX Automation Wizard (from the tools menu) to create an instrument for communicating with the server application.
Amaury R.
(2,937 Views)
