LabWindows/CVI
How to decode a set of datas received from serial port and display image on a canvas based on CVI ?
> I could not find the function CreateBitmap
Sorry, I was meaning NewBitmap ( ), standard CVI function.
With reference to the color table, you can find a sample color table for grayscale images in ConvertFile or ConvertBMP functions in my sample. For an 8bpp image the color table should be 2^8 = 256 int values. Values in image data are indexes in that color table.
Message 11 of 14
(1,218 Views)
Hi !
Thank you very much for your help!
I'm sorry to tell you that I could not understand the  algorithm in your sample .I build  a  simple project in the attachment.
I'd like you to help me modify it and indicate mistakes in it .
You could help me when you have time.
Thank you very much indeed.
Best Regards.
I wouldn't care success or failure,for I will only struggle ahead as long as I have been destined to the distance.
Message 12 of 14
(1,199 Views)
Hi, when posting a sample project to the forum you do not need to include neither the cvibuild.xx directory nor *_dbg.* files: these are regenerated every time by the compiler so there is no need to add them; furthermore, they use a lot of web space on this site. As an example, your project with only the relevant files occupy only 6 kB of space!
On the other hand, in your case you must provide instead a sample image and the corresponding data as received through the serial port and dumped to disk, as they are necessary to try and test the algorithm.
Message 13 of 14
(1,196 Views)
Hi !
Thanks for your information and for being so helpful.
I'll see to it.
Best Regards.
Message 14 of 14
(1,193 Views)
