LabWindows/CVI
How to determine if a panel is discarded%3F
Is there anyway to determine if a panel is discarded?
David
(4,470 Views)
I think that you can determine if a panel exists, i.e., has a valid panel handle, but after discarding a panel it's the same as if it had never been loaded into memory. So I am not aware of a possibility to distinguish between a discarded panel and a non-existing panel...
(4,461 Views)
