LabWindows/CVI
How to determine number of active channels
 I am writting an adapter that allows the user to select a number of channels and then write a buffer out to the channels.  I do not know how many channels will be used apriori and cannot tell the system, instead just allow them to send the channel string and then send the buffer.  Is it possible to poll the system to see how many channels were created?
Here is the example code:
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,Device_,"",(float64)minVolts_,(float64)maxVolts_,DAQmx_Val_Volts,NULL));
DAQmx  Get Number of created channels...
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,length/ ( Number of active channels ),0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
Thank you
(3,027 Views)
Ok I got it
 DAQmxErrChk(DAQmxGetTaskAttribute(taskHandle, DAQmx_Task_NumChans,&numChannels));
(3,014 Views)
