LabWindows/CVI
How to display selected popup menu Item
I am novice to the labwindows... My problem is that I have made a popup menu. The menu gets its items from a file. I want that when i click on any of the item, the specific text gets displayed on the control. Here is what I am trying
int CVICALLBACK quick_command (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
new_menu = NewMenu(command_menu,"Hello",0);
fileHandle = OpenFile("commands.txt",VAL_READ_ONLY,VAL_OPEN_AS_IS,VAL_ASCII);
line_buff = 0;
while (line_buff>-2)
line_buff = ReadLine(fileHandle,buffer_line,-1);
addMenu = NewMenuItem(command_menu,new_menu,buffer_line,-1,0,menu_Handle_CB,0);
InstallMenuCallback(command_menu,new_menu,menu_Handle_CB,0);
CloseFile(fileHandle);
GetCtrlAttribute(panelHandle,PANEL_QUICK_COMMAND,ATTR_LEFT,&command_left);
GetCtrlAttribute(panelHandle,PANEL_QUICK_COMMAND,ATTR_TOP,&command_top);
RunPopupMenu(command_menu,new_menu,panelHandle,command_top,command_left,0,0,0,0);
break;
default:
break;
return 0;
void CVICALLBACK menu_Handle_CB (int menuBarHandle, int menuItemID,
void *callbackPtr, int panelHandle)
char buf[10];
sprintf(buf,"%d",menuItemID);
SetCtrlAttribute(panelHandle,PANEL_QUICK_COMMAND,ATTR_LABEL_TEXT,buf);
Can anybody help me.... please....
Spark
(2,887 Views)
Hi Spark,
If I have correctly understood your problem, you want to display in a string control the exact text you have loaded from the file and displayed in the popup menu.
Here you find a modified version of your source that displays the text in a message box: you can modify it to adapt to your needs. In the code it is not necessary to install a callback for menu items.
This is the source code for your quick_command callback:
switch (event) {
case EVENT_COMMIT:
command_menu = NewMenuBar (0);
for (i = 0; i < 5; i++) {
sprintf (msg, "Menu item #%d", i + 1);
addMenu = NewMenuItem (command_menu, new_menu, msg, -1, 0, 0, 0);
GetCtrlAttribute(panel,control,ATTR_LEFT,&left);
GetCtrlAttribute(panel,control,ATTR_TOP,&top);
i = RunPopupMenu(command_menu,new_menu,panel,top,left,0,0,0,0);
GetMenuBarAttribute (command_menu, i, ATTR_ITEM_NAME, msg);
MessagePopup ("Menu", msg);
break;
default:
break;
But, after considering it for a while, I wonder why you are not using a ring control that executes the exact thing you are trying to mimic with the popup menu...
Hope this helps
Roberto
(2,870 Views)
