LabWindows/CVI
How to display windows hlp help
Does anybody know, how to display windows help file *.hlp (no *.chm), if a user clicks on the button?
(3,535 Views)
Hi pillas,
You can use the
SystemHelp function found in the Utility Library under the Miscellaneous category. This function launches the Windows Help viewer (winhelp.exe) and displays the help file.
Also, make sure to check out the SystemHelp() Pushes Back CVI Application Behind Other Applications When It Is Called KnowledgeBase as you might experience this behavior.
Best Regards,
Jonathan N.
(3,530 Views)
Thanks a lot
(3,528 Views)
