LabWindows/CVI
How to execute DOS command in cvi?
I'm looking for a function, which has the similar prototype like DosCMD(char *cmd) and could execute DOS command. Here, cmd could be "# ping 211.22.33.44", or "notepad.exe", or "winhelp", etc.
Thanks!
Jacky
(6,504 Views)
Executing DOS commands can be obtained in CVI using "system" or LaunchExecutable or LauncExecutableEx functions. Depending on which command you want to execute you may need to call it via the command interpreter command.com or cmd.exe.
Look at these threads that can be useful for your needs:
http://forums.ni.com/ni/board/message?board.id=180&message.id=762&query.id=121092#M762
http://forums.ni.com/ni/board/message?board.id=180&message.id=18772&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=180&message.id=12088&query.id=121063#M12088
(6,498 Views)
