LabWindows/CVI
How to find first empty row in Excel worksheet?
Using LabWindows/CVI 6.0 and Microsoft Excel 9.0 Object Library, how do I use ActiveX to find the last row of a worksheet with data in it? I have a template worksheet that I write measurement results to as the results are generated. So far I can successfully write the results via ActiveX to the template worksheet. Now, after saving the worksheet I need to be able to open it via ActiveX and determine which row is the last one containing data so that I may increment one row and write the next piece of data.
Thanks for the assistance.
(4,049 Views)
Aaron,
I'm not very familiar with Excel's ActiveX interface, however as an idea you could have a cell in Excel that holds the count of items found in the row where your column headers are. You can have this cell is some lost place or in a hidden cell. Your app can then read the value of that cell and know where to inset the data.
I hope this helps.
Juan Carlos
N.I.
(4,049 Views)
I had the same problem one year ago and I solved it as follows: I put in a for loop (counting from 1 to 65536, the maximum number of records an excel file can hold) the function, of the excel report library, that Get the attributes of a cell value. Between these attributes there is one that indicates the cell is empty. The best tip is to look at the examples supplied with CVI, into the directory excelreport. I hope this message will help you. Bie.
(4,049 Views)
