LabWindows/CVI
How to find if the network cable is unplugged?
Is there a function (in CVI or SDK) that can be used to find if a network cable is unplugged, in a WinXP environment?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,803 Views)
I don't know about SDK functions, but is has been suggested here to use the ping command to check for connectivity (it's not identical to a plugged-in wire, I know)
(3,798 Views)
I think the best way is just to use the ping function from the internet lib....
Kobi Kalif
Software Engineer
(3,796 Views)
I've already used the ping approach in other situations, but this doesn't satisfy me in this specific one.
For this reason I'm looking for a different function.
Vix
Using LV from 7
(3,792 Views)
You could call ipconfig and parse the output.
(3,775 Views)
Output from ipconfig depends on the language of Operating Systems: you find English terms on English OS, Italian terms on Italian OS, and so on.
And so it's impossible to parse this output searching for connection status.
Vix
Using LV from 7
(3,771 Views)
