LabWindows/CVI
How to fix compatibility issues?
I must have done something strange to my build environment because I now get the following messages when loading LabWindows CVI 7.1.
The project and source files worked well and I was able to build the dll.
How do I fix the compatibility issues that are mentionned in the following messages?
RayR
Additional Notes:  I did try the correct compatibility mode "Visual C/C++" and even tried the Borland mode.  I get the same error messages in both cases.  😞
I did not try to re-install CVI, yet.
Message Edited by Ray.R on 10-13-2009 11:32 AM
(3,590 Views)
This issue appears to be related to an installation of the CVI 2009 Beta, and as such, is being answered on the CVI Beta Forum.
NickB
(3,564 Views)
Hi Nick,
I found some related information.  Initially, I didn't realize that installing multiple versions could cause a compatibility problem (being used to LabVIEW).  Now this thread is almost a duplicate of another thread I had started.  - sorry -
http://forums.ni.com/ni/board/message?board.id=180&message.id=17675
http://forums.ni.com/ni/board/message?board.id=180&message.id=2320
(3,560 Views)
