LabWindows/CVI
How to generate 23khz using PCI-6723
HI,
My requirement is to generate a waveform of 23khz using PCI-6723.
I am able to generate frequency of 23khz when I changed the below parameters
Rate = 800kHz
Frequency = 23kHz
Amplitude = 2
But I would like to generate same frequency for another channel simultaneously
My Question is Simple : - How to generate frequency of 23khz for multiple channels using PCI-6723
Waiting for Reply's ASAP
Regards
krishna
(3,488 Views)
Krishna,
Change the physical channel control Dev1/ao0 to Dev1/ao0:1 to output the signal to analog output channels 0 and 1. Also, you will need to change the DAQmx write to be for multiple channels, and use a Merge Signals function to duplicate the waveform for both input channels. Check out the example I have attached.
Of course, you could always just connect two wires to one analog output instead.
Michael P
(3,475 Views)
Michael P
Thanks for your reply But can u send a same example in Labwindows
Regards
krishna
(3,471 Views)
Krishna,
Here is a link to an example program that shows how to perform Continuous Multi-Channel Analog Output with NI-DAQmx. This example allows every output channel to have a different output waveform type with different amplitudes. So, to have both channels output the same waveform you could just have both channels write the same waveform data.
Michael P
(3,454 Views)
