LabWindows/CVI
How to generate a sinewave with dutycycle using DaqmxwriteCtrFreq
HI,
We r required to generate a frequency signal using a sinewave with dutycycle.
Can we generate using Daqmx functions like DaqmxWriteCtrFreq? Can you post the example for generation of frequency signal using a sinewave with dutycycle.
Response required ASAP
Regards
krishna
(3,621 Views)
Hello Krishna,
Are you trying to create a sine wave with a configurable frequency or a square wave with a duty cycle?
If you want to create a square wave you can use a counter and a shipping example like those found in: C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Counter\Generate Pulse.
Good luck!
Micaela N
(3,602 Views)
