LabWindows/CVI
How to get first panel from set of top level panel?
Hi everyone:
I programed with CVI. I need to deal with all panels in my application. All the panels in my application are top-level panel. My question is how can i get first panel from those top-level panel?
Thank you very much!
(3,248 Views)
Hello Schoolworkwork,
I do not understand your question. Could you please precise it a bit more ?
If what you try to do is to split an .UIR file containing n*panels in n*.UIR files, you should first save your .UIR file into a .TUI one - trough Options >> Save in text format. It means that your .UIR file will be saved as a text file that you will be able to open and edit.
Then, you will have to divide this .TUI file containing n*panels into n*.TUI files. Please note that each .TUI file has to contain a [TUI Header File] and that in each .TUI file, you will need to set you panel ID as [Panel001] (If you plan to have m*panels, you have to set the ID panels from [Panel001 to [Panel00m]). After this kind of work, you should reimport the .TUI file into CVI to recreate the .UIRs - trough Options >> Load from text format.
Don't hesitate to provide us with more details if this is not the kind of information you need.
Message Edité par Mathieu Steiner le 02-28-2007 04:46 AM
(3,241 Views)
Thank you for your help! I am dealing with a CVI program. In that program, a lot of panel were defined. I want to programlly change most text name like Label text name, button text name. so i need to get first panel, then during that panel, i would like to get attributes and set name for them. and so on , i want to do that for each panel.
(3,236 Views)
Hello back,
Then, you should try the following functions:
   SetPanelAttribute (panelHandle, ATTR_TITLE, "MyNewPanelName"); // for panels only
   SetCtrlAttribute (panelHandle, PANEL_NUMERIC, ATTR_LABEL_TEXT, "MyNewControlLabel"); // for controls labels
(3,223 Views)
