LabWindows/CVI
How to get status returned by the last process
For a similar applicatin I made some attempt with some system function that may be of help in this case: FindFirstChangeNotification Win32 API function sets an event when some file in a folder is changed.
I am attaching a simple project that monitors a single file in a folder, receives notifications and if file is changed displays its content on screen. To test the example simply start the program, set the folder and file name and start monitoring: when you write in the file and save it, the program is notified and displays updated content in a textbox. There is no need to close the monitored file: simply save it (unless the file is opened in exclusive mode, in which case you are likely to get I/O errors).
The application works well for local files, while it gets errors while monitoring folders on a remote server and I didn't find a way to solve this.
Message 11 of 15
(1,905 Views)
Ah, having an event of course is much nicer!
Message 12 of 15
(1,902 Views)
Much thanks, Roberto!
However, a couple compiling issues:
  1. The icon wasn't found (no big deal, I just removed the link)
  2. The two attached libraries (libhpdf.lib and Version.lib) were not included in the zip.
  3. The project doesn't have the INI file library attached (again, no big deal, I attached myself).
Message 13 of 15
(1,892 Views)
I was in a hurry and didn't pay attention to those details. Anyway, neither the icon nor the libraries are needed to run the sample: this one is the reduction of a bigger test program I had that made use of them but I stripped out the relevant instructions. And I forgot to add the config file too... Smiley Surprised
Message 14 of 15
(1,887 Views)
I am coming to think that some kind of event does exist in Windows for almost every condition I can think of! Smiley Wink
The problems I have are:
  1. Knowing that an event handling function actually exists for some problem I may have
  2. Understanding how it may work (Windows APIs normally aren't so user friendly and deeping in the documentation can be a challenge sometimes!)
Message 15 of 15
(1,883 Views)
