LabWindows/CVI
How to get the cell number of a table
is this possible to get the row/column number of a cell where a mouse is clicked? Accutally, i want to implement a dynamic list which the user can "Add" or "Delete" some entries. The "Add" function is all right. The "Delete" function makesme upset because I cannot catch the cell's location where the mouse is choosing. I tries to use "Active Cell", it seems does not work. Do you have any clue? is this possible to implement the dynamic list using the "listbox"? thanks
(3,051 Views)
The solution to this problem is in the use of GetTableCellFromPoint command: look at how to use it  here
(3,044 Views)
