LabWindows/CVI
How to get x position from a canvas control
How to get a x position from a canvas control after call func CanvasDrawTextAtPoint (panel, ctrl,distxt,text_style, MakePoint(x,y), VAL_LOWER_LEFT);
for example: x=5,y=20;
distxt="This is a test"
I want to get a value of x after calling above function. Anybody know? thanks in advance
(3,223 Views)
I'm not sure I understand your question completely, but my guess is that you would like to know where the right edge of your text string is, in the canvas. Assuming that you are not changing the x and y offsets of the canvas, the coordinates used by the canvas are just pixels. So to find out the right edge of the string, you only need to find out how wide it is, and then add the initial x to it.
The function GetTextDisplaySize can tell you how much space a given string takes, when using a particular font. Just pass it the same distxt and text_style parameters that you are passing to CanvasDrawTextAtPoint
Luis
NI
(3,218 Views)
Your guess is correct, that func. is the one I needed
Thanks LuisG
(3,201 Views)
