LabWindows/CVI
How to handle formfeed received on rs232?
I am new to CVI, however have good knowledge of microcontroller based C programming. I am trying to figure out how to handle formfeeds sent by a device.
HARDWARE:
1) I am running LabWindows CVI 2013 on my PC
2) I have a electronic hardware which can serially communication using RS232
The Issue:
Basically the hardware responds to the commands sent through the serial port. previously i had been using HyperTerminal for the communication. Hence when the device responded with new data it sent form feed first and then the data.
Now I wanted to move on to a HMI development, I have setup the C code in CVI to send out serial commands and using
InstallComCallback (COM_PORT, LWRS_RXCHAR, 0, 0, Event_Char_Detect_Func, 0);
I am trying to read the data into a buffer and display it in a text box
void CVICALLBACK Event_Char_Detect_Func (int portNo,int eventMask,void *callbackData)
char readBuf[1000] = {0};
int strLen;
strLen = GetInQLen (COM_PORT);
ComRd (COM_PORT, readBuf, strLen);
SetCtrlVal (panelHandle, PANEL_OUTPUT_STRING, readBuf);
return;
However I am receiving small boxes instead of form feed. I used "LWRS_RXCHAR" so I could read each character individually and then maybe handle formfeeds but the compiler requires readBuf[] to be more then one character showing that it reads the complete RX data que before sending it to textbox (OUTPUT_STRING).
I can always make changes to the micro controller, but I want to know if there is a proper way of handling such a situation? or maybe I am doing someting wrong in the code above?? Help needed.
(4,019 Views)
Basically you could do what you are doing simply skipping the form feed, tat it: read in a soparate buffer and copy from this one to the effective char variable skipping the form feed.
But you have other alternatives:
  • Use ComRdTerm to read the string until the form feed is received:
    ComRdTerm (COM_PORT, readBuf, strLen, 14);
    In this case you should not have the form feed in the receive buffer
  • Setup the com callback to fire on the form feed (se the help for reference):
    InstallComCallback (COM_PORT, LWRS_RXFLAG, 0, 14, Event_Char_Detect_Func, NULL);
    In this case the com callback will be fired when a form feed is received anf you can read with ComRd but you must discard the form fedd (last character read)
(4,011 Views)
