LabWindows/CVI
How to have code execute at a specific date/time?
I am looking for any advice/example code on how to have a section of code execute at a specific system date/time. I am settting up a test to run over several days and need to have one instrument change ranges with code at a specific date and time. I am thinking of a do/while loop, but before I batter my head against the bench, I thought I would ask the group.
Gregg
(3,439 Views)
If your program control is in a loop, then within the loop, I would use a check of the time and date.
If your structure is otherwise, I would create a timer callback to check the time and date.
The pieces of code I would use are calls to GetSystemTime() and GetSystemDate().
Use the returned values to check for your specific date and time.
(3,433 Views)
