LabWindows/CVI
How to hide the console when we use GetKey()
hi use the GetKey(),
k=getKeY();
if(k==VAL_F1_VKEY){
How can hide the console when i execute this snippet....
Thanx and regards,
venki
(3,725 Views)
Hi Monky!
   I think there's no way to hide console, I mean, in GetKey docs, you'll find:
      Note
    GetKey detects keystrokes only in the Standard I/O window. GetKey does not detect keystrokes in windows
                  you create with the User Interface Library or in the console window of a Windows Console Application.
   To intercept keystroke in your panel, for example, I suggest you to use EVENT_KEYPRESS (value = 7).  For example, in your main panel callback, you can write:
int CVICALLBACK PanelCallback (int panel, int event, void *callbackData,
        int eventData1, int eventData2)
    switch (event)
        case EVENT_CLOSE:
             QuitUserInterface(0);
             return 0;
            break;
        case EVENT_KEYPRESS:
             YourFunction( ... );
             return 0;
            break;
    return 0;
If you look at EVENT_KEYPRESS definition, you find also this:
   #define EVENT_KEYPRESS              7   /* eventData1 = keypressed, */
        /* eventData2 = pointer to keypressed */
so you get also the value of key actually pressed.
Of course, this is valid if you have a panel, in your application.
Hope it helps, please let me know!
graziano
(3,717 Views)
...and of course, the panel should have focus!!!
(3,715 Views)
