LabWindows/CVI
How to import VB.NET dll into LabWindows/CVI?
I'm trying to call VB.NET dll from LabWindows/CVI. I can import a reference to the dll, but CVI was unable to recognize the methods within the Class.
(3,598 Views)
Since CVI is a C programming language it will not be able to call methods or access members in a exported class. Probably the easiest way to get around this, is to create a wrapper DLL in a language that can access exported classes.
Basically you create a C exported function in the wrapper DLL that calls the method that you want to access in the .NET DLL. At the end you have a DLL that exports a C function for every method in the .NET DLL.
I hope this helps!
Juan Carlos
N.I.
(3,598 Views)
