LabWindows/CVI
How to include wchar.h
Is there a way to include this header file? There is some code that I'm porting over that uses that library and I'm wondering if anyone has found a way around this? The closest solution I've found is using mbsupp.h for multibyte characters in the ansi_c.h library.
(4,346 Views)
You can find here the list of ansi_c functions that can be used in CVI. Related to widechar, there is only conversion from/to multibyte(mbtowc, mbstowcs, wctomb, wcstombs) and string length(wcslen).
What functions do you use in your code that are not available in CVI?
Constantin
(4,306 Views)
