LabWindows/CVI
How to make Panel Frame transparent or Remove (Urgent) ?
Hi all
There is a child panel in mp cvi application, i have a background picture on child pannel. how to remove panel frame or transparent ?
Reference sceenshot is attached
Umer
(3,863 Views)
in the UI editor you can set 'Frame style' to hidden, which results in a frame thickness of 0.
(3,859 Views)
I have already check this option, but the same result as in attached screenshot
(3,838 Views)
Could it be that what you are seeing is the picture border? The picture control has a "Show frame" checkbox that determines whether its 3d border is visible or not.
(3,829 Views)
