LabWindows/CVI
How to make a word header with an array?
I work on labwindows cvi 8.0 and i use the word report librairy. I want to generate a word report with an header and in this header I want to make an array. Using the function WordRpt_SetHeader() I can create an header but it's not an array.
How do I use this function to create an array in the word header? or Do I use an other function to do that. Smiley Sad
For example: I want to create an header with an array (3 colums and 2 lines). in cell 1.1 i want to inser a picture (logo), 1.2 a title, 1.3 a string, 2.1 an auto ref, 2.2 a string and 2.3 a string.
Thank you.
(3,225 Views)
It is not possible to use this instrument driver to do it.
You will need to use the low activeX functions to do it.
I guess there is a function allowing to define a objet as the header of the file.
You can see this example which use the low activeX functions in CVI.
Johan G.
(3,174 Views)
