LabWindows/CVI
How to map key-value pairs in CVI?
I need dictionary type of data structure where is key-value pairs. I would like to get value by key.
In C++ this can be done with CMAP class.
(3,319 Views)
Try to use ini fileformat and use the read/write .ini style libarary
(inifile.fp )
[section1]
tag1=value1
tag2=vaalue2
[section3]
tag1=value1
tagn=valun
lajos
"Orbis" wrote in message
news:50650000000800000041FF0000-1079395200000@exchange.ni.com...
(3,319 Views)
Thanks.
I never thought about applying INI format for this.
I guess it works eventhough it is not that nice way to code it.
I guess I could create fuction that mimics the CMAP class by using INi fileformat. That's way the actual implementation wouldn't show in the upper level that is using the maps.
Thanks!
(3,319 Views)
