LabWindows/CVI
How to modify using one fixed file to using a file control just like path control in my Activex project?
Pls see the attachmet! It is my cvi project using Activex. it is a mediaplayer programm. But it just can play a fixed media file in the fixed path.If I want to move the media file to another path, it cannot play.So i want place a path control in the UIR, so it can randomly search the file through path contrl dialog interface. But i don't know how to modify my program to achieve the target. Could you give me a hand? I use CVI6.0. Thanks a lot!!
(2,884 Views)
Add an Open button. In its callback function, call FileSelectPopup and MediaPlayer_IMediaPlayer2SetFileName.
See the attached project with modified .UIR and .C files.
PS: when you're posting a project, you don't need to include the huge files like .EXE, .CDB, .NIOBJ. It will help us download your files.
(2,884 Views)
