LabWindows/CVI
How to obtain an IUnknown pointer from an ActiveX object
I am very new in ActiveX and also just getting familiar with COM (Component Object Model).
How can I obtain an IUnknown pointer from an ActiveX object?
my code is:
//some variables:
    FdtType_FdtXmlDocument SupportedProt = 0;
    IUnknown *interfacePtr;
    HRESULT error;
    CAObjHandle TCICommSrv;
    ERRORINFO errorInfo;
//the code part:
   DisplayPanel (panelHandle);
    CA_InitActiveXThreadStyleForCurrentThread(0, COINIT_APARTMENTTHREADED);
    error = CA_CreateObjectByProgIdEx("TCI.SimaticCommunicationServer.1", NULL, &IID_IUnknown, 1, LOCALE_NEUTRAL, 0, &TCICommSrv);
    CA_GetAutomationErrorString (error, buffer, buffersize);
    CA_DisplayErrorInfo(TCICommSrv, "error info", error, 0);
    CA_ServerQueryInterface(interfacePtr, &Fdt_IID_IFdtCommunication, &newInterfacePtr);
  //end code
As far as I know the QueryInterface method is for gathering the interfaces supported by the ActiveX server? Am I right?
That is why I seek for if the implemented interface (Fdt_IID_IFdtCommunication) exists? So at this point I don't know
what should be the first parameter (interfacePtr) for this QueryInterface function. Somehow the interfacePtr is not good.
Roland
(3,991 Views)
Use CA_GetInterfaceFromObjHandle instead of CA_ServerQueryInterface. The CA_ServerQueryInterface library function is for use in CVI-created COM server programs. Your program is a COM client and to get the IUnknown (or any other) interface from the external COM server object, you should use CA_GetInterfaceFromObjHandle.
(3,964 Views)
Mohan,
thank you for your answer, indeed it helped.  Smiley Wink
Roland
(3,937 Views)
