LabWindows/CVI
How to open a excel file without using activeX automation in Teststand
I know I  can use ActiveX automation to open a specialize excel file. However, long time ago, I once knew there was another way to open excel file, that way was using "call executables" step type to call a txt file and then indirectly open excel file.
Hope somebody can help me this.
Thanks!
Jacky
(3,127 Views)
you can simply use the "LaunchExecutable" function as follow:
 error = LaunchExecutable ("excel.exe c:\\test.xls");
(where c:\test.xls is the path and file you want to open)
This function return without waiting the excel to exit. Use "system()" if you need your program stop
Bye
(3,124 Views)
