LabWindows/CVI
How to open an excel document
I am having some problems here with opening an excel worksheet. I have a macro in it that automatically runs upon opening and then closes excel. However, I cannot open the document through labWindows. I have tried using system, IO open and some people mentioned something about a program called ghostvision. Can someone point me in the right direction. Thanks a lot for the help.
Sebastian
(3,987 Views)
Hey Sebastian
Well you can use activeX to open/close excel........refer to the samples in your NI directory....
C:\.................\National Instruments\CVI70\samples\activex\excel
Hope it helps.....
k1_ke
(3,982 Views)
Hello Sebastian,
I think using the function OpenDocumentInDefaultViewer will be the easiest solution to your problem.
(3,979 Views)
Perfect!Smiley Happy OpenDoc was exactly what I needed.
Thanks for the help,
Sebastian
(3,966 Views)
