LabWindows/CVI
How to pass FILE I/O pointer to external DLL?
I'm compiling an external C++ DLL with Borland's compiler then importing the DLL into Labwindows. After I create a console application I can get the following code to successfully print to the console:
fprintf(stdout, "hello\n");
But:
OUTFILE = fopen("out.txt", "w");
fprintf (OUTFILE, "hello\n");
creates the out.txt file but nothing ever gets written to out.txt.
Are there any special requirements needed for FILE I/O or passing FILE pointers into a DLL?
(3,606 Views)
"ni user" wrote in message
news:50650000000800000082C40000-1078497998000@exchange.ni.com...
> console:
> But:
When you open the file to check file contents, make sure that the file was
closed after it was written. The file creaotor application also may need to
be exited before checki
ng the file.
HTH
Mohan Pawar
(3,606 Views)
I tried your solution and it works. Thank you!!!
I need to be much more careful about FILE I/O when using DLLs. So instead of passing FILE pointers into the DLL I'll close the file first in the calling routine, then pass a character string and re-open the file in the DLL, then close the file in the DLL before exiting.
(3,606 Views)
