LabWindows/CVI
How to play a music file with Windows media player included as ActiveX?
Is there an easy way to play an mp3 file with Windows Mwdia Player, that I put in the panel as an ActiveX?
(3,714 Views)
The Easy way is to call the appropriate method to play a selected file from the activeX.
See the example attached...
AlessioD
(3,702 Views)
National Instruments has published a media player example here.
You can just change the call to MediaPlayer_IMediaPlayer2SetFileName() to pass the path of your MP3 file.
The example was created in CVI 7.0. I loaded it into CVI 6.0 and it gave me a warning that the UIR was created in a later version, but it ran fine and played a couple of MP3's that I tried. I'm running CVI 6, Media Player 7, Windows 2000.
(3,693 Views)
Thank you AI S,
I was overlooking the main subject to this forum post. The example I attached is for LabVIEW. It works basically the same as the one you mentioned for CVI.
AlessioD
(3,687 Views)
