LabWindows/CVI
How to print multiple panel/pages to create a single pdf/fax
I have written a software that fill a bitmapcontrol with all that I have to print (text,images etc). Actually I fill and print it, page by page simply with subsequents PrintCtrl(). All is OK when I print to a printer, but if I want to create a fax or a pdf file with multiple pages, it create multiple pdf/faxes, one for each page instead of one fax/pdf file. I have tried to play with SetPrintAttribute(ATTR_EJECT_AFTER, 1 or 0) to queue multiple pages in one print but without any result. Any suggestion (without rewrite a lot of code to use NiReport)?
Many thanks in advance,
Raffaele
(3,895 Views)
Hi Rafael,
LabWindows/CVI is not able to print multiple panels/pages to a single PDF. The ATTR_EJECT_AFTER will simply line feed the current page when the entire print job is finished and then continue the next job on the new next page.
Joel
(3,895 Views)
There are some steps which you need to follow.
1- Put the documents in place.
2- Press (COPY / SCAN) to switch to the scan mode screen.
3- Use Ups and down arrow to  to select <Remote Scanner>, then press [OK].
4- Double-click the [Canon MF Toolbox 4.9] icon on the desktop.
5- Click on [PDF].
6- Select [PDF (Multiple Pages)] in [Save as Type].
7- Specify the required settings according to your needs, and then click [PDF Settings].
8- Specify the required settings according to your needs, then click [OK].
9- Click [Start].
When documents are placed on the platen glass:
(1) Set up the next page, and then click [Next].
(2) When scanning is complete, click [Finish].
You can also follow https://googlefaxfree.com/ where you can get different articles related to Fax.
(2,497 Views)
I wonder what is the point of reviving a 16-year-old discussion, and furthermore offering a solution different from what the OP asked for! You speak about a manual process, tied to a specific printer, when the OP was looking for a coding solution... Smiley Frustrated
(2,485 Views)
